Merge Simulations
If you are simulating multiple processes and your simulation models have some things in common, you may want to combine them into one to run both at the same time.
You can do this with the Merge Simulations feature under the Advanced Tab. This allows you to select another simulation to be merged into your currently open simulation.
This feature can be beneficial if you are working in a simulation team, and many pieces of a larger model are being worked on individually. Once the Merge Simulation feature is used, the selected simulation will appear in the simulation window of your current model and will copy over all information. This means you don’t have to worry about copying over Visual Logic, variables, and spreadsheet data as this feature will take care of that for you.
