Process Mining
Process mining aims to visualize, understand and improve your business processes by extracting data from event logs generated by ERP, Workflow Management and other information systems.
Process mining offers objective, fact-based insights, derived from actual data, that allows you to assess, analyse, and enhance existing business processes by answering both compliance-related and performance-based problems.
In Simul8 2021 you can harness the power of process mining and go a step further by using simulation to experiment further and get quick insight.
So, let’s get started!
Step 1
When you open Simul8, select the option to Create New Process Mined Simulation.
Step 2
Next, you will be given the choice of whether to run one of Simul8’s included pre-populated example data sets or to import your own data set.
Step 3
Once you have selected your data set, you will need to define your columns and date/time format. As a minimum, the Unique ID, Activity, and Start Time columns will need to be assigned.
Step 4
Hit build, start simulating and gaining insight! You will see that a clear structure with a detailed Arrival Schedule is automatically generated.
Happy Simul8ing! If you have any questions, just drop us an email and we'll be happy to help.
