Overtime Activity Routing In
This feature is available only in Simul8 2016 and later.
When Overtime is enabled, you can use an Activity's special routing options to control what time periods the activity should work.
To access an activity's special routing options select an Activity>Routing In>Options
Block During Overtime
Select this option to disable the Activity when the simulation is in overtime.
Block During Normal Time
Select this option to disable the Activity when the simulation is in normal time.
