Detailed Transaction Log by Area
Detailed Results Logging allows you to collect large volume of very precise timing and Label value data.
It can be accessed through the Results menu on the Home tab.
Make sure the Log detailed, transaction-by-transaction, data option is ticked.
Use the Add button to add a start and finish point for the Result collection. Use the Up and Down hand button to alter the order that results will ultimately appear in the output sheet.
The results are collected into a spreadsheet and can be viewed by navigating to the Home Tab > Results Manager > Transaction Log >View.
