Templates
Simul8 Templates are partly built simulations designed for specific business situations. Wizards in these templates step you through building a simulation specific for your needs.
Access our example template files from the File tab.
You can also create your own templates by using Save As and selecting the template option, .TS8 file.
Template Licensing allows you to license and distribute your Simul8 Templates to other Simul8 users without allowing them to alter anything that they should not.
Simul8 Template Licensing is only available as part of Simul8 Professional.
Simul8 Template Licensing allows you to turn off unnecessary toolbars, protect the internal workings of your simulation, and distribute your work securely.
