Simulation Window
The simulation window is the main representation of your simulation within Simul8.
You create your simulation by adding objects onto the simulation window. The contents of the window are updated as the simualtion runs so that you can see a visual representation of what is happening.
To inspect the detailed parameters of any object on the screen, simply click on the object and use the contextual menu's that appear in the ribbon. Inspecting the object also lets you look at its performance measures (results), collected during a simulation run.
