When are Resources Required?
Resources must be at an Activity before the Activity can start work and Work Items will not normally move to an Activity before it can start work.
However, if “collect routing” is used to collect a number of Work Items into an Activity for a task, then it is possible to de-select the default “require resources before collecting any Work Items” check box in the Resources dialog box. Reach this dialog box from the Activity's dialog box.
