Text Names Are Accurate
Speeds up simulations by failing VL commands where text does not exactly match object names.
None required.
By default Simul8 will first look for an exact match for the object name. If a match isn't found then Simul8 will then try a few other variations such as changing cases. Fast search tells Simul8 only to look for the exact text you have entered to give searches as fast as possible.
