Set Field Number
Sets a numeric field in a database. This command creates a new record in the database table. Nominate the database to be added to by using the Open Database command, then use the Set Command to place a new record into the database
- Simul8 SQL Database - SQL Database where insert or update has been started.
 - Field - Name of data field
 - Number Value - Number value to be inserted into field
