Select Current Work Item
Selects a Work Item as the current Work Item. If there is not a Work Item at the selected location the current Work Item becomes zero.
  • Simulation Object - Object where the work item is currently located
  • Position - Position where the work item can be found in the object (0 = “last item in Queue”)
