Run External Program
Runs externally supplied program and waits for it to exit
Exe file name - Full path or just exe name, in double quotations.
Additional message - Text sent to external program via command line, in double quotations - can be blank by entering “”.
For example, to run PowerShell directly from Simul8, use the following command:
Run External Program “C:\Windows\system32\WindowsPowerShell\v1.0\powershell.exe” , “”
- If just the executable file name is supplied, Simul8 assumes the file path is where the Simul8 file is saved.
- A file path should be specific and not contain a variable i.e. “%SystemRoot%\ system32\WindowsPowerShell\v1.0\powershell.exe” may not work.
