Previous Sheet Result Vertical Confidence
Tells Simul8 that confidence limits in auto sheet results are above/below the mean
None required.
Use this command when building your own result displays with Simul8 internal spreadsheets and want results calculated for you automatically when a trial is run. Use the Sheet location remove from Results Summary command first to set results to be recorded on your cell.
