Previous Sheet Result Auto Mean
Tells Simul8 that a result's mean should be placed on the sheet automatically.
None required.
Use this command when building your own result displays with Simul8 internal spreadsheets and want results calculated for you automatically when a trial is run. Use the Sheet location remove from Results Summary command first to set results to be recorded on your cell.
