Link Simulation Objects
Links two simulation objects with a routing arrow.
  • Source Object: Name of simulation object or variable
  • Destination Object: Name of simulation object or variable
  • Travel Time: Simulation time units to travel between objects
We do not recommend using this command at run time. It is intended only to be used in Before Reset or On Reset to make structural changes to your simulation before the simulation run or trial begins.
