Watch our latest webinar on managing supply chain uncertainty with Simul8
Explore, learn and connect with Simul8 in our upcoming webinar.
Find out more
Contact
Blog
Sign in
Software
Simul8 features
What is simulation?
FAQs
Latest updates
System requirements
Simul8 for education
Applications
Applications
By industry
Healthcare
Manufacturing
Automotive
Call centers
Pharmaceutical & medical devices
Supply chain & logistics
Defense
Business process management
Government & justice
By business goal
Process improvement
Process mining
Digital twins
Lean Six Sigma
Robotic Process Automation
Digital transformation
Capital investment
Plan new processes
Remove bottlenecks
Build business cases
Case studies
Learn to Simul8
Learn to Simul8
Training classes
Online coaching
Academy
Consulting
Getting started videos
Resources
Pricing
Support
View all categories
Home
Getting started
Simulation - a guide to the technique
Listen
Level of Detail
Build Rough & Ready, then Refine it
Work closely with your client
Verification
Warm up time
Visual exploration
Accuracy of results
How much of this do I need?
What is simulation?
Building a basic simulation
Getting results from your simulation
Simulation key concepts
Simulation objects
Simulation objects
Start Points
Queues
Activities
End Points
Resources
Connecting simulation objects
Work items
Results collection period
Results
Run
Trials
Getting around
Getting around
Ribbon tabs
Home tab
Data & Rules tab
Insert tab
View tab
Visual Logic tab
Advanced tab
File tab
Quick access tools
Shortcut keys
Simulation drawing tools
View tools
Feature reference guides
All features
Animation
Animation
Non-time-based Animation
Arrivals (Start Point)
Arrival Planner
Arrival Times from CSV File
Constraining Arrivals
No Arrivals
Start Point Schedule
Unlimited Arrivals
Batching
Batching
Batch and Collect tutorial
BPMN simulation
BPMN simulation
BPMN simulation objects
BPMN Activity
BPMN End
BPMN Gateway
BPMN Start
BPMN Sub Process
BPMN Swimlane
Importing BPMN
Importing XPDL
Charts
Charts
Charts from spreadsheets
Customizable charts
Exporting chart data
Histogram
Make time graph
Pie charts
Time graphs
Clock
Clock
Warm up period
Clock setup tutorial
High speed clock
Components
Components
Component detailed options
Component palette
Components and Visual Logic
Components with Labels & Distributions
Unpacking Components
Dialogs
Dialogs
Buttons on Dialogs
Combo boxes
Custom menus
Spreadsheets in Dialogs
Distributions
Distributions
Probability Profile
Probability Profile
Copy/Paste
Discrete/Continuous
Lock/Unlock percentage of a bar
Probability Profile tutorial
Time Dependent Distributions
Re-sampling Overruns Between Time Slots
Time Slot For Time Dependent Distributions
Access Information Store
Ask Visual Basic Check Box
Average Distribution
Bernoulli Distribution
Beta Distribution
Binomial Distribution
Bounded Distribution
Combination Distributions
Distribution Summary
Distribution Viewer
Erlang Distribution
Exponential Distribution
External Distributions
Fixed Distribution
Gamma Distribution
Geometric Distribution
Label Based Distributions
Log Normal Distribution
Named Distributions
Negative Binomial Distribution
Normal Distribution
Pearson V Distribution
Pearson VI Distribution
Poisson Distribution
Rounded Uniform Distribution
Time Absolute Distributions
Triangular Distribution
Weibull Distribution
Efficiency
Efficiency
Detailed Efficiency
Resources on Breakdown
Stop Work Immediately
Graphics
Graphics
Image sets
Using Graphics tutorial
Information Store
Information Store
Special Global Data Items
Types of Global Data Items
Labels
Using Labels
Attaching a Label
Labels Control Work Item Images
Labels Tutorial
Segregate Results
Special Labels
Deleting Labels
Lean - Value Stream Mapping
Lean - Lead Time Chart
Overtime
Overtime
Overtime Activity Routing In
Overtime Results
Preferences
Preferences
Continuous
Display
Distance
Files
Finance
Results Preferences
Undo in Simul8
Queue Graphics
Queue Graphics
Conditional Queue Graphics
Resources
Resources
Find Resource
Label Based Resources
Pooled Resource Results
Pooled Resources
Resource Availability
Resource Dependent Timing
Resource Graphics
Resource Individuality
Resource Matrix
Resource Moves With Work Item
Resource Pools within Resource Pools
Resource Priorities
Resource Results
Resource Routing Arrows
Resource Schedule
Resource Schedules
Resource Travel Time
Shift Dependent Resources
When are Resources Released?
When are Resources Required?
Resource Requirements
Detailed Options
Release Resource As
Resources Tutorial
Using More Resources
Routing
Routing
Route Out By Sequence
Routing In
Routing In by Percentage
Routing Out
Routing Out By Condition
Routing Work Without Routing Arrows
Results
Results
Adding Results to the KPI Summary
Export to PDF
Export to Template
KPI History
KPI Summary
Removing Results from the KPI Summary
Results All Dialog
Results By Work Type / Group
Results Export
Results Export to V•I•S•A
Results Manager
Save Results as Text
Start Point Results
Switching off Results Collection
Time Interval Results
Shifts
Shifts
Shift Behavior
Shift Gantt View
Shift Pattern Detail
Simul8 COM
Simul8 COM
Python and Simul8 COM
VBA and Simul8 COM
Simul8 Finance
Simul8 Finance
Financial Input Summary
Simul8 Process Objects
Tanks
Pipes
Process Oven
What's Different About Process Objects
SQL
SQL
Setting Up a Database Input
Sub-Windows
Sub-Windows
Transport
Transport
Loader And Unloaders
Paths
Transport Example
Vehicle Results
Vehicles
VBA Extension
VBA Extension
Error Messages
Building your own Visual Basic Simul8 program
Current Work
Signals from Simul8 to VB
VBA Extension Commands
Visual Logic
Visual Logic Commands
Debugging Visual Logic
How to use the Visual Logic Builder
Math Functions
Navigating Visual Logic
Object Properties
Where Can You Use Visual Logic
Visual Logic Tutorial
Adjust Route in Percent to 100
Beginners’ Tutorial in Visual Logic
Copy Local Variables
Function Keys running Visual Logic
Functions
Local Variables
References List
Sheet to Cycle Matrix
Speed Analysis
Syntax Highlighting
Time Check VL
Visual Logic Command Browser
Visual Logic Find
Visual Logic Folders
Visual Logic Interface
Visual Logic Libraries
Visual Logic Syntax and Tips
XML
XML
Results XML
SolutionXML
Change Random Numbers and Run
Redo
Undo
Snap to Grid
Snap to Angle
Actions
Activity Graphics
Activity Results
Activity Timing
Activity Timing By Label
Advanced Random Number Control
Aligning Objects
All Object Status
All Work Items
Attach Spreadsheet to Work Item
AutoCAD drawings
AutoCAD Import
Background Image
Batch by Condition
Batching At Start Point
Batching by type
Batching In
Bending Routing Arrows
Buttons On the Simulation Window
Calendars
Carbon Emissions
Change Overs
Change Over Time Tutorial
Changing Routings
Collect/Assemble Work Items
Command Line Options
Command Script
Compare Simulations - Track Changes
Conduct Trial
Convert To
Conveyors
Cost by Work Type
Ctrl Drag
Customizable Buttons
Custom Object Properties
Custom Reports
Cycle Matrix
Data Graphics
Deleting a route arrow
Deleting Objects
Disco Import
Display+
Documentation
Drawing Routing Arrows
Duplication Wizard
Editing Images
End Point Graphics
End Point Results
Excel Connections
Exit Times to CSV File
Exit Work Item Type
Experiment Builder
Export all Google Sheets Connections
Export Google Sheets Connection
First at Start Time
Flip Selected Object Image
Go to End of Warm Up Period
Go to Simulation Time
Grid
Groups
Halt Simulation at Limit
High Level Analytics Panel
High Volume
Hold Work Here
Hot Spots
Image Lists
Images
Import All Google Sheets Connections
Import Google Sheets Connection
Index with Groups
Input Summary
Interruptible
Invisible Objects
Jobs Matrix
Label Editor
Layers
LIFO
Links Dialog
Lost Work Items
Memo
Minimum Wait Time
Minitab Export
Mirror Selected Object Image
Monitor Simulation
MORE Plot
Multi-task Timing
Non-Object Based Costs and Revenues
Object Contents
Object Speed Code Lists
Object Titles
OptQuest for Simul8
OptQuest FAQs
Overview Window
Parallel Processing
Path Densities
Pick and Place
Power and Free / Fixed Pitch Conveyors
Presentation Mode
Prioritize Queue Contents
Prioritizing Activities
Process Mining
Progress Bar
Protection
Queue Results
Queue Visualization
Quick Launch
QuickView
Random Numbers
Replicate
R integration with Simul8
Rotate Selected Object Image
Route Drawing Mode
Run Later
Scenario Manager
Scheduled Maintenance
SDX Support
Sensitivity Analysis for Distributions
Share
Sharing Your Simulation on the Web
Shelf Life
Shift Dependent Activities
Shift Dependent Conveyors
Show Routing Arrows
Simul8 Assistant
Simul8 Object Explorer
Simulation Properties
Simulation Speed Options
Simulation Window
Simulation Window Tabs
Sliders
Start Point Graphics
Start Point Timing
Start Up
Stat::Fit for Simul8
State Charts
State Chart Timing
Sub Process Timing
Tables
Text Box
TimeView
Timing Orientation
Transaction Logs
Transaction Log by Area
Transaction Log by Object
Transaction Log by Resource
Travel Time
Travel Time Matrix
Trial Calculator
View Objects of Type
Views
Visio
Visual Data
Visual Validation
Visual Verification
Wait Till Exit Clear
Watch Window
Work Item Images
Work Item Tracking
Zoom
Paddle
How Do I?
How Do I?
Automatically Loading Simulations
Calling an External DLL from Simul8
Collect Interval Results
Connected Activities
Connect Multiple Simulations
Copying Objects
Creating an Excel Interface
Custom Interfaces
Debugging My Simulation
Importing Data
Making Your Own Results
Prioritizing Work
Speeding Up Your Simulation
Troubleshooting
Troubleshooting
Installation support
Network License
Common messages during or after NLS installations
Network License User Options
Roaming or Network Checkout
Write Protecting the S8 Directory
Installer Command Line Options
All Licenses in Use
Beginner's Tutorial Runs Every Time
Can I run Simul8 on my Mac?
Can't Find Excel
Cannot Find Program
Editing Large Images
Install Incomplete: Message 77015
My Simulation Runs Too Slowly
Online and Desktop synchronization
Out of Memory
RegError: C0 CFP:218100450
Simul8 Asks You to Activate Every Time You Launch
Small Font Size
Usage Log Expiry
Simul8 Online
Simul8 Online
Accessing Simul8 Online
Account Management
Account Management
How to purchase a subscription
Upgrade from monthly to annual subscription
Change email address
How to add OptQuest to your credit card subscription
How to add OptQuest to your invoiced subscription
Online and Desktop
Password Management
Troubleshooting
Using External Files
Latest Changes
Examples
Glossary
Tutorials
Insert Row
Insert Row into Simul8 Spreadsheet.
Spreadsheet - Spreadsheet to insert row into, set [c,r] to location of new row.
Related Commands
Copy Sheet Area
Copy Sheet Column
Copy Sheet Row
Count Sheet Area
Count Sheet Area Non Zero
Sum Sheet Area
Search Sheet Area
Clear Sheet
Clear Sheet Area
Clear Sheet Data Only
Insert Column
Insert Cell Vertical
Insert Cell Horizontal
Delete Row
Delete Column
Delete Cell Vertical
Delete Cell Horizontal
Simul8 Spreadsheets
