Get Result
Copies a KPI Summary value to a Global Data Item. The Low Confidence Limit and High Confidence Limit options in Result Type return % confidence limits as currently set by the user in the KPI Summary.
For use on End Trial Visual Logic.
  • Global Data Item (Number)
  • Result Type (Current Run, Average, Confidence Limit etc)
  • Result (Choose from any on the KPI Summary)
Simul8 Get Result VL Syntax
Note: you will need to make sure that the Result parameter has previously been added to the KPI Summary. You should also make sure the name of the Object is typed in before the name of the Result (for example End 1: % In System Less Than Time Limit).
Really useful for compiling results reports or basing your next run on the result of a previous run.
