Get Resource Travel Time
This command returns the current Travel Time for a Resource between two locations.
- Resource: The Resource object that the travel time is needed for
- From Location: The location from where the resource is traveling
- To Location: The location that the Resource is traveling to
- Travel Time: The Global Data Item that will receive the returned value
This command can be used at any time during the simulation run and could be used when setting the Resource requirement of a Work Center in Visual Logic. For example, the Resource requirement for a Work Center might be set to be the Resource with the shortest travel time.
