Get Current Run Result Value
Gets any instant result from results dialogs.
  • Simul8 Global Data Item - Global Data Item that receives the Result
  • Simulation Object - Any simulation object
  • Result Code 1 - Number. For valid codes for this object click RIGHT on KPI Summary Items
  • Result Code 2 - Number. For valid codes for this object click RIGHT on KPI Summary Items
Results code are available by right clicking on an object's of the same type results in the KPI summary. You can then remove the object from the KPI Summary, it doesn't need to be there except to get the right code values.
