Fast Object Search Always
Assume case is a perfect match for all “SET Obj_Var = TEXT” searches.
None required.
By default Simul8 will first look for an exact match for the object name. If a match isn't found then Simul8 will then try a few other variations such as changing cases. Fast search tells Simul8 only to look for the exact text you have entered to give searches as fast as possible.
