Extract Date and Time elements
The Extract Date and Time elements command extracts years, months, days, hours, minutes and seconds from a variable containing this information in a text format. This information is stored in separate variables allowing the user to use all components of the date as the user pleases.
  • DateTime - Text variable containing the date and time information
  • Year - Numerical variable that will be used to store the current year
  • Month - Numerical variable that will be used to store the current month
  • Day - Numerical variable that will be used to store the current day
  • Hour - Numerical variable that will be used to store the current hour
  • Minute - Numerical variable that will be used to store the current minute
  • Second - Numerical variable that will be used to store the current second
This command is very useful in combination with the command “Format Local Time”.
 Extract Date and Time elements lcl_txt, lcl_year, lcl_month, lcl_day, lcl_hour, lcl_min, lcl_sec
This example shows the extraction of date and time elements from the variable lcl_txt. The other variables are named in such a way that it is clear what they are used for.
It is quite easy to construct a date or time from these separate variables. See the example below:
SET gbl_date_txt = lcl_day+"/"+lcl_month+"/"+lcl_year
This examples shows the construction of a date in a format like “1/1/2010” by combining the different numerical variables with the / character into the correctly formatted date.
