Evaluate Expression from Text
Returns a value from an expression described in text. Not intended to be fast!
- Returned value - Text var or Number that is to receive the result
- Expression in text - Text string that looks like an expression, can be a single Global Data Item
- Set Global in Text - Sets a Global Data Item (variable) to an value or text where the global variable is named in a text string.
- Variable in text - Text string describes a global variable to set e.g. “Var1”
- Value - Any expression, the value is placed in the global variable in parameter 1
This command is only available with Simul8 Constructor. Email sales@Simul8.com for more information about Constructor.
