Create Shift
Creates a new Shift.
Shift - Name of the Shift (in quotation marks)
Creating Shifts can be created without the use of Visual Logic, through the Shifts Dialog on the Build tab. Still, this command can be useful when a model is used for a wider range of occasions, where the number of Shifts and Shifts’ Properties are subject to change.
Annotated Example
In the following example, we have created a spreadsheet named ssWorkingHours. Create Shift is used here within a Loop Command to quickly create 10 Shifts, whose names are stored on the ssWorkingHours Spreadsheet.
