Geometric Distribution
The Geometric distribution is a discrete one and it provides the probability of a first success (in a series of experiments) requiring a certain number of independent trials, each with the same success probability p. Simul8 asks for this parameter between 0 and 1.
The Geometric distribution can be used to set a Label. For example, it can set the value to the number of failed tests before a success which in turn determines the number of re-works loops needed before continuing the process or simply another form of Routing.
