Ask Visual Basic Check Box
In the dialog box that sets up a named distribution (where you set the type of distribution etc) you can also instruct Simul8 to “Ask Visual Basic” about the distribution before each time the distribution is sampled. This enables you to change the parameters of the distribution as the simulation runs, if you should require this.
