Unpacking Components
Components can be “unpacked” when they are introduced to a new simulation.
To Unpack a Component drag and drop it from the toolbar to the Simulation Window, then double click on the icon to open it. Select the Toolbar tab and select to Remove Component Layer from the drop-down list.
There is also an option in this list to remove the layer into a sub-window.
If a Component uses Dialogs then the Component Properties box is not directly displayed. To open the Component Properties, click on the Component to open the Dialog then hold the Shift and Ctrl keys down (at the same time) and then click on the Cancel option button on the Dialog.
