Component Palette
The Component Palette is a repository that is displayed down the left hand side of the simulation window.
There are a number of steps to go through to create the Component Palette.
First, navigate to the Object Repository folder (usually in Simul8 application folder). Within this folder create another folder called “Component Palette”. Within the new Component Palette folder create one or more sub folders. These sub folders will create tabs in the palette so that the components can be organized, for example, by type of operation.
Save some components to the Component Palette folders and ensure that the Component Palette is switched on via the Toolbars dialog. The components can be dragged and dropped on screen in the usual way from the Component Palette.
