Resources - Examples
Resources are used to constrain Activities. The following examples present various uses of Resource Objects. It is recommended to familiarize yourself with adding Resource requirement to Activities by checking this tutorial.
- Resource_Moves_with_Work_Item.s8 Using a moving truck as a Resource, this example presents a simple application of the Resource Moves with Work Item feature.
- Select_Resource_by_Label.s8 Shows how to use Label-based Resources, where Resource 1 and 2 deal with different types of Work Items.
- Shift_dependent_Resources.s8 Shows how to set the availability of Operators in the Morning and Afternoon Shifts of the day.
- Pools_and_select_resource_by_label.s8 This example features both Pooled Resources and Select Resource by Label, and shows how to use both of these features to manage skills at a Call Centre.
- Pooled_Resources.s8 Shows a simple application of Pooled Resources
