Parameters are pieces of information passed to a block of Visual Logic.
Parameters are added and edited via the parameters button on the Visual Logic Editor.
Parameters can be used to pass Number values, Text Values, Whole Spreadsheets or references to Simulation Objects to the Visual Logic block.
To create a new parameter, click on the parameter button in the Visual Logic Editor and then click the new button.
The name and type of parameter can be edited.
Parameters can be removed by clicking the Erase button.
The order that parameters are entered represent the order that the values must be passed to the Visual Logic block using the [Visual Logic Call command].
