Select Simulation Object
Selects a simulation object so that you can perform an operation on it, for example to copy it.
  • Object - 303Clear Object Selection
  • Deselects all selected simulation objects - Returns the latest copy of an object
  • Original Object - The object that was previously copied
  • Object Data Item - Global Data Item to return copy object
Can be called at any time (but most likely to be called before “Count Selected Objects” command is used. Might be used to set a Custom Property on a group of objects).
