Scheduled Maintenance
Scheduled Maintenance allows you to define planned maintenance events on any Activity, with the maintenance period referencing Simul8's Calendar feature. This means that you can easily swap and refine maintenance plans, allowing you to run many What-If scenarios in short amounts of time to help you minimize flow reduction and maximize up-time.
Unlike breakdowns, Scheduled Maintenance does not happen randomly, as it is designed to occur exactly when you input the start and end times of the maintenance period.
The Scheduled Maintenance feature gives you full control over when the Activity will be shut down for maintenance, how long it will be down for, how frequently the maintenance occurs (using a repeat value), and whether or not a Resource is required to perform the maintenance.
It runs in combination with existing features for simulating breakdowns, resource shortages, and changeovers.
Step By Step to set up Scheduled Maintenance
Enabling the Calendar
- The Calendar must be used so that you can enter the Start / End of the Scheduled Maintenance in MM/DD/YYYY (or DD/MM/YYYY) HH:MM format
- Open Scheduled Maintenance from Build tab > Schedule
Note: the Calendar will format itself to whatever localization settings your PC is set to.
Understanding the Scheduled Maintenance Interface
Simulation Object – The Activity that will be scheduled to shut down for maintenance
Start – Beginning time of maintenance
End – End time of maintenance
Repeat – Time to repeat (in current simulation time units)
Resource – Resource to be used to perform the maintenance
Visual Logic On Maintenance Start - Once the scheduled maintenance Start interval is triggered in the simulation, this Visual Logic will be called
Visual Logic On Maintenance End - Once the scheduled maintenance End interval is triggered in the simulation, this Visual Logic will be called
Setting Up Scheduled Maintenance
Once you have completed the steps above to set up the simulation's calendar, you are ready to input the maintenance schedule.
- Fill out your information in the Scheduled Maintenance dialog
In the example above, Activity 1 will go down for maintenance at 17:00 on March 28th and will return to service at 09:00 on March 29th. The repeat value dictates this will happen weekly on the same day each week (assumes running in minutes, 09:00 - 17:00, 5 days per week: 60 minutes * 8 Hours * 5 days = 2400 minutes). The second instance of maintenace will occur 2400 simulation minutes after the inital start time and end 2400 simulation minutes after the initial end time. There is no Resource required to perform the scheduled maintenance in the example image above.
