Object Titles
The Titles of an Object can be displayed at any location around the object, and can be wrapped or offset.
Select any Object and then on it's Graphics tab in the ribbon. The title can be shown or hidden by ticking or unticking the Show Title check box or you open its Title Properties.
To move the title to the left or right change the X offset value. Setting the X offset value to a number less than 15 or a negative value will move the title to the left.
Changing the Y Offset value to a number greater then the default of -24 will lower the title on the screen.
To wrap longer titles change the Wrap Text Beyond value to a number greater than 0. We suggest you start at a value of 50.
