Exit Times to CSV File
This feature writes to a csv file the exact times Work Items exited a simulation. It will also record all Label values.
Check the 'File' option on the End Point dialog and then select the file to write to.
The csv file must be closed before running the simulation.
Once the simulation is finished running the csv file can be opened and the output examined.
