Importing XPDL
You can import your XPDL process diagrams into Simul8 giving you the power and insight of simulation to help understand the best way to improve your process.
Importing XPDL into Simul8 is easy:
- Export your process diagram from your current BPM tool into XPDL xml file format
- In Simul8, go to the File Menu and select the New tab
- Click Import from XPDL
- Select the XPDL file you want to import
- Simul8 will then convert your XPDL diagram into a simulation.
Now you can start using the analytical tools inside of Simul8 to get vital insights into how your process will perform in the real world.
