Visual Logic Tab
Simul8 Visual Logic Tab
Simul8 Visual Logic Time BasedTime Based
Drop down list of all Visual Logic events in the simulation that occur when the simulation is running.
More information
Simul8 Visual Logic Action BasedAction Based
Drop down list of all Visual Logic events in the simulation that are based on actions occurring.
More information
Simul8 Visual LogicAll
Drop down list of all Visual Logic in your simulation.
Simul8 Visual Logic Time CheckTime Check VL
Visual logic that is executed at regular time interval when the simulation is running and the clock reaches one of the time check intervals.
More information
Simul8 Visual Logic User ScheduledUser Scheduled
Specify Visual Logic sections to run at specific time points or on recurring schedules.
Simul8 Visual Logic NewNew
Create a new independent section of Visual Logic.
Simul8 Visual Logic Last EditedLast Edited
Opens the last section of Visual Logic that was edited in this session.
Simul8 Visual Logic BookmarkGo to Bookmark
Quickly jump to lines of Visual Logic you have marked.
More information
Stop on Next VL
Check this box to stop the simulation running when the next Visual Logic section is executed.
Disable All
Disable all breakpoints so they are ignored and Visual Logic will execute without pausing when they are hit.
More information
Simul8 Visual Logic Clear AllClear All
Remove all Visual Logic break points.
More information
Simul8 Visual Logic Speed AnalysisSpeed Analysis
Identify your Visual Logic sections that are taking a long time to run.
More information
Simul8 Trace Call StackTrace Call Stack
Call stack lets you see the chain of Visual Logic sections executed to get to the current point where it has been stopped.
Simul8 Execution LogExecution Log
Every executed line of Visual Logic is logged to a text file.
More information
Simul8 Visual Logic Custom PropertiesCustom Properties
This feature allows any simulation object to hold information about that object in a similar way to labels do for Work Items.
More information
Simul8 Visual Logic Speed ListSpeed List
Object Speed Code Lists are a way of quickly set Object Variables.
More information
Simul8 Visual Logic LibraryLibraries
Save your code in External Libraries to re-use in other simulations or share with others.
More information
Simul8 Visual Logic Password ProtectPassword Protect
This will password protect your Visual Logic. Users will be prompted to enter a password when trying to open Visual Logic sections
