This tab is not enabled by default. It can be enabled through preferences.
Warm Up Period
The warm up time is the time that the simulation will run before starting to collect results.
More information
Scenario Manager
Run different scenarios with the same simulation one after the other to find the best outcome.
More information
OptQuest
A SIMUL8 add-on provided free with SIMUL8 Professional. Optimize your simulation to find the best input values to meet your criteria of success.
More information
Stat::Fit
A SIMUL8 add-on provided free with SIMUL8 Professional. Fit a distribution to your data. Stat::Fit help files are provided with the Stat::Fit tool
More information
Sensitivity Analysis
Analyze your named distributions in terms of how sensitive the results are to changes in these inputs.
More information
Work Item Types
Manage the work item type in your simulation.
More information
Random Sampling
Change the random numbers being used.
More information
Monitor Simulation
The simulation monitor lets you see the detailed activity taking place within SIMUL8's internal simulation engine.
More information
Watch Window
A tool to monitor values of expressions as your simulation executes for debugging.
More information
All Work Items
Tools to monitor and investigate the work items in your simulation.
More information
Macros
Record and playback mouse and keyboard clicks.
More information
Merge Simulations
Select another simulation to be merged into your currently open simulation.
Compare Simulations
Using the xml format compares two simulations to highlight the differences.
More information
Manage Team Changes
If both teams start developing from the same simulation their changes can then be merged back together into one simulation.
Run Later
Schedule your simulations to run at another time.
More information
Run Command Script
Write a simple set of commands to run a series of simulations
More information
