The Detailed Transaction Log by Object automatically records every task an Activity or Resource performs. It reports the start and end time of each task.
The Log is accessed through the Results button on the Home tab
To use the Log, open the Log - all objects in the simulation will be listed. Select the objects a Log should be created for by checking the box beside the object name. Run the simulation and then double click on a selected object in the Log list, this will open the Log for that object.
