• Getting Started
  • Simulation Key Concepts
  • Getting Around
  • Feature Reference Guides
  • How Do I?
  • Glossary
  • Trouble Shooting
  • Examples
  • Tutorials
  • SIMUL8 2013 Feature List
Examples
The following and many more example simulations are all installed on your PC when you install SIMUL8. You can quickly access them through the File Tab.
Also check out the back issues of our newsletter and the learning zone for more examples.
Animation
  • Animate Activities
  • Changing Work Item images with labels
  • Changing work item images using labels 2
  • Animate Activities and change travel time
Prioritizing Work
  • Prioritizing work
  • Interruptible Activities
  • Using Due label to only do remaining processing time after interrupting work
Resources
  • Select Resource by label
Routing
  • Controlling routing using a label
  • Creating a feedback loop using label routing
  • Routing using the Jobs Matrix
  • Routing different work types using the Jobs Matrix
Timing
  • Control timing and routing with the Jobs Matrix
  • Label based timing
  • Time Absolute Distribution
  • Time Dependent Distribution
Optimization
  • Makepack.S8 - Example simulation used in Optquest tutorial.
  • Call_Center_1.S8 - Example simulation used in Optquest tutorial.
Others
  • Collect and batching: Example 1, Example 2 and Example 3
  • Batch by Type
  • Pull expired work items out of a Queue
Show pagesourceOld revisions IndexLogin
