Simulation Window
The simulation window is the main representation of your simulation simulation within SIMUL8.
The contents of the window are kept constantly up-to-date so that you can see what happens in your simulation as the simulation runs. From this you gain insights into how the ideas you have about your system.
You create your simulation on this window by drawing a picture of the decision system you want to simulation.
Each icon on the simulation window represents an object in the simulation simulation (or an icon can also represent a simulation Sub-Process because your simulation can exist at a number of different levels).
You inspect the detailed parameters of any object on the screen, or to look inside any of the Sub-Processes, simply click on the object. Inspecting the object also lets you look at its performance measures (results), collected as the simulation simulation ran.
