Preferences lets you select a number of options that customize the way SIMUL8 works with your simulation.
Access your preference settings from the options button on File tab.
You can save a particular set up of SIMUL8 preferences as your default preferences for all new simulations. Create a new simulation with no simulation objects etc. Then click the SET DEFAULT button in Preferences. The SET DEFAULT button is not available if SIMUL8 contains any objects. The SET DEFAULT button will not change existing simulations.
