Wait Till Exit Clear
In an Activity Routing In dialog choose the Options tab. Check “Wait till exit clear” if the Activity should not attempt to draw work in until its exit is able to accept work. Note this test is only performed at the time the work is loaded and it cannot be used with routing out disciplines where the exit route cannot be determined at the time the Work Item is loaded.
