Roaming or Network Checkout
In order to temporarily use your Simul8 NLS seat remotely (without a network connection to the server), you need to disconnect it first. For that:
- Go to: File > Network License > Disconnect license
To check back in:
- Go to: File > Network License > Re-Share License
When you are part of a Simul8 NLS set-up, this should look as follows:
