Connect Multiple Simulations
With Simul8 it's possible to have multiple simulations connected to each other, so what happens in one simulations affects what happens in another.
To do this you use the Exit Times to CSV feature to write the outputs of one simulation to a CSV file. Then use the Arrivals from CSV file feature to read the outputs into another simulation.
Download the following two files to see this in action. Run Simulation One first to generate the exit data. Next, run simulation two, this will pull the exit times from Simulation One and use them as its arrivals.
Simulation One - Generate exit data
Simulation Two - Read exit times from Simulation One as arrivals
