Visual Logic Tab
Time Based
Drop down list of all Visual Logic events in the simulation that occur when the simulation is running.
More information
Action Based
Drop down list of all Visual Logic events in the simulation that are based on actions occurring.
More information
All
Drop down list of all Visual Logic in your simulation.
Time Check VL
Visual logic that is executed at regular time interval when the simulation is running and the clock reaches one of the time check intervals.
More information
User Scheduled
Specify Visual Logic sections to run at specific time points or on recurring schedules.
New
Create a new independent section of Visual Logic.
Opens the last section of Visual Logic that was edited in this session.
Go to Bookmark
Quickly jump to lines of Visual Logic you have marked.
More information
Stop on Next VL
Check this box to stop the simulation running when the next Visual Logic section is executed.
Disable All
Disable all breakpoints so they are ignored and Visual Logic will execute without pausing when they are hit.
More information
Clear All
Remove all Visual Logic break points.
More information
Speed Analysis
Identify your Visual Logic sections that are taking a long time to run.
More information
Trace Call Stack
Call stack lets you see the chain of Visual Logic sections executed to get to the current point where it has been stopped.
Execution Log
Every executed line of Visual Logic is logged to a text file.
More information
Custom Properties
This feature allows any simulation object to hold information about that object in a similar way to labels do for Work Items.
More information
Speed List
Object Speed Code Lists are a way of quickly set Object Variables.
More information
Libraries
Save your code in External Libraries to re-use in other simulations or share with others.
More information
Password Protect
This will password protect your Visual Logic. Users will be prompted to enter a password when trying to open Visual Logic sections
