View Tab
Object Status
Show a colored square beside each simulation object to indicate it's current status.
More Information
Visual Validation
See the properties of your object onscreen to help you verify your inputs.
More Information
Hot Spots
Highlight how objects are performing within your simulation.
More Information
Density
The thickness of each routing arrow is changed to let you to compare the number or Work Items that have traveled down each route visually.
More Information
QuickView
Additional window to quickly edit commonly used properties for objects.
More Information
Explorer
Additional window to quickly find objects.
More Information
Quick Launch
Displays Financial information for your simulation and can be customized to create an interface for your simulation.
More Information
Magnifying Glass
Zoom in selected areas of the screen.
More Information
All titles
When ticked all titles of simulation objects become visible.
Image Library
Manage the images being used in your simulation.
More Information
Clear All Display+
Clears all the images and text that have been drawn onscreen using display+
More Information
Sub Process
Sub Process let you create a hierarchical simulation, with some objects placed in separate nested windows.
Create a new sub window
Reopen all closed sub windows
Close all sub windows
More Information
Grid
Displays a grid onscreen to help you line up objects and images onscreen.
More Information
Custom Views
Views automate the process of manipulating the screen to show certain aspects of your simulation.
More Information
Zoom
Zoom in or out to view more or less detail of an area of your simulation.
More Information
100%
Reset the simulation window back to 100% zoom level.
More Information
