Data & Rules Tab
Simul8 Data and Rules Tab
Simul8 ClockClock Properties
Set up the working hours of your simulation and the display of the clock.
More information
Simul8 CalendarCalendar
Run your simulation against a calendar of dates.
More information
Simul8 ShiftShifts
Set up the shifts for your Resources and Activities.
More information
Simul8 LablesLabels
See all the Labels in your simulation and create new ones.
More information
Simul8 DistributionDistributions
See all the distributions in your simulation and create new ones.
More information
Simul8 DistributionCreate Distributions
Create your own custom distribution.
More information
Simul8 SpreadsheetsSpreadsheets
A list of all the spreadsheets in your simulation.
More information
Simul8 Information StoreInformation Store
The information store is a where all the global data items are stored. Global data items are items of data that can be used in your simulation to measure or control what is happening.
More information
Simul8 View Object of TypeView Objects of Type
Lists of the objects that form the structure of your simulation.
More information
Simul8 GroupsGroups
Put simulation objects into and manage your groups.
More information
Simul8 Resource MatrixResource Matrix
See where your Resources are assigned in one central table.
More information
Simul8 Resource ScheduleResource Schedule
See where your Resources are scheduled in one central table.
More information
Simul8 Scheduled MaintenanceScheduled Maintenance
Apply scheduled downtime to Activities in your simulation.
More information
Simul8 Input SummaryInput Summary
A summary of all the objects and their properties in your simulation.
More information
Simul8 Quick BuildQuick Build
Quick Build enables you to automatically produce an entire simulation based on parameter data from pre-filled tables.
More information
Simul8 Travel TimeTravel Matrix
Allows you to edit the travel times between all relevant objects in your simulation from one easy menu.
More information
Simul8 Job MatrixJobs Matrix
Control the sequence of work via a matrix rather than routing arrows.
More information
Simul8 Cycle MatrixCycle Matrix
An alternative method to describe routing in your simulation, where you define each of the cycles of activity at your Activites.
More information
Simul8 LinksLinks
View and change the routing between all your simulation objects.
More information
Simul8 OverheadsOverheads
Specify fixed costs and revenues that apply to your whole simulation.
More information
Simul8 FinanceFinance Summary
The Financial Summary allows you to change the financial inputs for all objects in your simulation.
More information
Simul8 ExcelExcel Connections
Import data from Excel and export results using an easy connection wizard.
More information
Simul8 SQLSQL Connections
Import data from SQL and export results using an easy connection wizard.
More information
Simul8 RR Connections
The R connection allows you to export data to R and run scripts directly from Simul8
More information
Simul8 GoogleGoogle Sheet Connections
Import data from Google Sheets and export results using an easy connection wizard.
More information
