Advanced Tab
Warm Up Period
The warm up period is the time that the simulation will run before starting to collect results.
More information
Experiment Builder
Run different Experiments with the same simulation one after the other to find the best outcome.
More information
OptQuest
A Simul8 add-on. Optimize your simulation to find the best input values to meet your criteria of success. Get in touch to find out more.
More information
Stat::Fit
A Simul8 add-on. Fit a distribution to your data. Stat::Fit help files are provided with the Stat::Fit tool. Get in touch to find out more.
More information
Sensitivity Analysis
Analyze your named distributions in terms of how sensitive the results are to changes in these inputs.
More information
Work Item Types
Manage the work item type in your simulation.
More information
Random Sampling
Change the random numbers being used.
More information
Monitor Simulation
The simulation monitor lets you see the detailed activity taking place within Simul8's internal simulation engine.
More information
Watch Window
A tool to monitor values of expressions as your simulation executes for debugging.
More information
All Work Items
Tools to monitor and investigate the work items in your simulation.
More information
Macros
Series of features that allow you to record, open, and view the building of a simulation.
More information
Multiple Files
This series of features allows you to merge simulations, compare versions and record changes made by team members within a simulation.
More information
Run Later
The run later feature allows you to schedule simulation runs, trials or scenarios at a later time.
More information
Run Command Script
This feature lets you write a simple set of commands to run a series of simulations.
More information
