Set Chart to Auto Update
Tells Simul8 whether a chart should be automatically updated at runtime or whether the user will update it manually using the Refresh Chart or Rebuild Chart commands. If the chart is set to be updated automatically Simul8 will redraw it each results synchronization interval.
  • Chart: Name of the chart
  • Auto Update: 1 to auto update, 0 to update manually
Use only in the On Reset or Before Reset Visual Logic events.
