Remove Resource Requirement
Removes the requirement from a Work Center. An alternative approach is to Set Resource Requirement to 0. the advantage of Remove Resource Requirement is that all reference to the Resource is removed from the Work Center.
  • Work Center - Work Center where the resource requirement is to be removed
  • Resource - Resource to remove
