Results XML
The contents of the KPI Summary can be saved to an XML file. XML files are easily used by many applications that need to interchange information.
At the end of a Run or Trial select this option from the result export drop down menu on the Home tab
An XML file will be created in the selected folder that contains all the results of the KPI Summary.
Information can also be saved to an XML file using Visual Logic.
