Sequence Of Processing Work
Sequence of processing Activity Visual Logic.
Before a Work Item is selected for routing in
This logic is processed when there is some chance that the Activity will be able to load a Work Item. If the Activity is busy and full this logic is not processed. If there is no available work in feeding simulation objects this logic is not processed.
After loading a Work Item
This logic is processed after a Work Item has been selected and loaded to an Activity but before the processing time for the Work Item at this Activity has been set (using the appropriate distribution).
On Work Complete
When a Work Item's processing time ends this logic is obeyed.
Immediately after On Work Complete is obeyed the out going batch size is calculated (from Batching in Routing Out).
Label Actions
For each item in the batch Label are changed and Label action Visual Logic is obeyed. Detail»
Before Exit
When each Work Item leaves the Activity, and also when the Work Item is blocked. When the item is Blocked the Before Exit Code runs continuously see Before Exit Visual Logic and Label Based Routing
On Exit
When a Work Item is leaving an Activity this logic is obeyed. This happens before the Work Item actually leaves but after it is determined that it definitely will leave. It is not possible to reroute the Work Item to a different destination at this time. Labels can be changed but these changes will not affect routing. Do not delete the Work Item.
